disable switch bluetooth
disable switch access
Description
Disables management access on a switch.
Syntax Description
Default
N/A.
Usage Guidelines
Using this command disables access to the switch using the following protocols: SSH, Telnet, HTTP, HTTPS, and SNMP.
The following example disables management access on a switch:
# disable switch access
Warning: This command will disable access to switch via SSH, Telnet, HTTP, HTTPS and SNMP. Existing such sessions will be logged out and user can access the switch only using console connection.
Continue? (y/N) Yes
This command was first available in version 33.1.1.
Platform Availability
